width
lingus
09-03-2002, 10:34 AM
I am looking to add some width to my wheel/tire. I want to put on 31" OR 32" SSR with a torsion crank. Should I get aftermarket wheels (15") and by what? 8" or 10"? What size tire will fit with a 15" rim? Can you get 32" on a 15" rim, as compared to a 31" on a 16" rim? Is this thinking correct. Basically I want the tires to stick out of the wheel well about 1 or 2". What can I do? Any pics to see what they would look like?
Thanks you guys are great!!!!!!!
wqbang
09-03-2002, 10:42 AM
You are better off staying with stock wheels if you plan to actually take your rig offroad. Any other offset-width rim is going to cause rubbing and potential steering issues.
evergreen
09-03-2002, 11:02 PM
ssr's run bigger than what they state. so a 32 would probably not fit without a lift. i could be wrong but if your tires stick out a great distance from the wheel well, when your suspension flexes it might hit the fender and cause some damage.
rrdstarr
09-04-2002, 12:34 AM
How is this.....when I do my tire swap from 31" swampers to my Grabbers. The Grabbers are actually wider than the swampers!!! I built a shelf to store the tires and almost had to widen it!!
