Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Celica
Old 10-01-2006, 03:16 PM   #1
dat280zxguy
dat280zxguy Normal reputation
Low power under 2500
90 Gt with 5sfe motor. 150k miles.
Minimal power under 2500 rpm, then the motor comes to life, prcatically surges. I have only had the car 1 week, previous owner didn't think about it being prob, just always let clutch in at 3000+ rpm all the time......and just replaced clutch 6 months ago...lol
Replaced plugs, wires, cap and rotos, air filter.
Thinking next to try injectors along with fuel filter.
Anyone with similar problem or suggestions welcome.
dat280zxguy is offline   Reply With Quote
Old 10-13-2006, 09:56 AM   #2
pat052003
pat052003 Normal reputation
Send a message via Yahoo to pat052003
Re: Low power under 2500
I have a 90 ST and everything under the hood is practically brand new, radiator, distributor, alternator, timing belts, battery, intake & exhaust manifolds, injectors, fuel rail, spark plugs and cables, water pump, oil pump, a/c compressor & drier, brake booster and master cylinder, and new clutch. And on top of all that I just had a 3 angle valve job and port and polish done to the cylinder head. The car only has about 26k miles more than yours and it does the exact same thing. Don't quote me on this and there may be someone in here that would know better than me, and you could also even call a Toyota tech. and ask him, but if I had to guess I would say it had something to do with the way the CPU is programmed, and I am about to have mine reprogrammed so I'll let you know if the problem ceases afterwards.
pat052003 is offline   Reply With Quote
Old 10-14-2006, 06:01 AM   #3
dat280zxguy
Thanks for the input, Pat.
Just an update, I have replaced the fuel filter with no change.
I do however notice that while the motor is still very cold, it has significantly better throttle response under 2500 rpm. My thought is that the cold start injector is providing more fuel.
Pat, your thought on the programming may be correct.
Appreciate any posts if anyone has similar probs.
Anyone ever see dyno tests on stock 90-93 Celicas?
Old 10-15-2006, 10:07 PM   #4
91 Celica St
AF - Advisor
91 Celica St Normal reputation
check your timing. mine used to do that, it would feel like it was misfireiring then all the sudden get all its power back after 3 grand, it ended up being my timing and a bad d-cap
91 Celica St is offline   Reply With Quote
Old 03-22-2007, 07:34 PM   #5
UNCRck2
UNCRck2 Normal reputation
I have the same problem i got a cold air intake and the problem has lessend a lot but still not there but i have 130k and didnt chang cluch but i am getting the timing belt changed and timeing redone so that may help but it may be a ecu problem idk tho but cold air intake helps alot
UNCRck2 is offline   Reply With Quote
Bookmarks
Google
Web AF
