Replaced IAC but still stutters at idle
xqqme2day
09-30-2006, 09:36 AM
After replacing the IAC (major KIA dealer price ripoff), I thought things would improve - but alas, it's less severe stuttering, but still hiccups every 20+ seconds at idle. And still, after 4 months of this, no CHECK ENGINE light, so I assume no codes.
So, now what?
BTW, while I haven't really looked, can someone point out where the fuel filter is located? (1999 2.0l engine)
e_powers
09-30-2006, 10:32 AM
So, now what?
have you ever changed plugs? might need tune up.
the fuellter is in the ejngine bay . lean on the left fender look past the battery towards the engine block.
xqqme2day
09-30-2006, 05:46 PM
Yes, it had a tune up - just before this problem developed - which has always pissed me off (KIA service).
BTW, located fuel filter, will have to wait to replace when engine is cooled down, looks like tight fit.
hvac1000
10-02-2006, 02:52 PM
Did they replace the ALL the wires for the coils when they did the tune up? Most people miss this part. They just screw in a set of plugs. The wires (all the wires including the short jumper harness) and plugs are changed here all the time. They get hot and overtime
xqqme2day
10-03-2006, 10:34 AM
I'm not able to determine if the coil packs were replace - but yes, they did do new wires. Overall, I have good performance and gas mileage, so this looks to be a idle only condition. Should I pull the top off and replace the coils anyway? I removed the MAF and lightly blew air by/around it. Also cleaned MAF plug/contacts. Will replace fuel filter today. Any other thoughts?
MeettheCreeper
10-03-2006, 02:45 PM
Pull the vacuum line off the fuel psi regulator and have someone rev the engine. Its probably leaking. If it leaks fuel replace it.
If you have a misfire it is going to throw a P0300 code for the specific cylinder.
Rarely have I had a coil go bad.
xqqme2day
10-12-2006, 08:27 AM
The stutter has become worse, and now it stalls (nearly) on accelration from dead stop. I still believe it is electronic, as there is no problem while in PARK, only when in gear (D/N/R) And still no ENGINE light, so I assume no CODES. True/false? Is a visit to KIA Service my only real choice?
xqqme2day
10-20-2006, 09:34 AM
OK, now that fuel filter is back in place, ready to test regulator. Anyone (LMP??) got a pic of it, so I am 100% on target? And, if it does leak, will it leak back on vacumn port side, or where? And is this another KIA only part, or is NAPA going to have it?
