New PICS of my fiberglass sub pod...
ci5ic
09-02-2002, 05:15 PM
Well, the fleece didn't work out too well before, I couldn't get it to stretch right in the center area of the frame, so I went and got some nylon lycra material and stretched that over the frame instead. Then, I added a coat of fiberglass resin and let it harden. Next step is to re-inforce the backside of the lycra with fiberglass matting (and some woven mat on the outside as well). Here's the after pics:
Some pics of the pod with the speakers laying on top of it (this is how the subs will eventually be mounted:
http://files.automotiveforums.com/uploads/696568lycra01.jpg
http://files.automotiveforums.com/uploads/447650lycra02.jpg
http://files.automotiveforums.com/uploads/460648lycra03.jpg
Pics of the pod without the speakers:
http://files.automotiveforums.com/uploads/215119lycra04.jpg
http://files.automotiveforums.com/uploads/684416lycra05.jpg
so-cali
09-02-2002, 06:29 PM
Looks pretty good. Are u gonna be able to see the front of the cone of the subs though after its mounted in the car? Or will it only be viewed from the back?
PaulD
09-02-2002, 10:12 PM
I never thought about you mounting them like that ........ you should chrome the baskets, or come up with a really cool paint scheme.
ci5ic
09-02-2002, 10:17 PM
I would really really like to have a polished look for the baskets, but I'm curious how that would be done? I couldn't just have the whole speaker dipped in chrome, right? Would I have to somehow dissassemble the speaker to have it done? I was also thinking about powder-coating the baskets, but I don't think the speakers could hold up under that kind of heat...
kicker1_solo
09-03-2002, 12:12 AM
mmmmmm.....solo barics, yummy. Those are the best subs I have ever owned. :)
Startin' to look good. :)
PaulD
09-03-2002, 10:46 AM
I did this once ...... I had an isobaric pair and I painted the frame and side of the magnet of the one showing the same color as the car exterior. I put newspaper in there to protect the cone, then taped off the label before painting.
-=BOOMER=-
09-03-2002, 05:28 PM
Wow was the lycra absorbent enough to soak up the Resin? I never though of using it before? Also how’s the strength on it? I know you said you were going to reinforce it but just curious on how it was before?
Looking good though.
ci5ic
09-03-2002, 08:50 PM
The lycra worked pretty good... It stretched really nicely, but when you put the staples through it, it rips the lycra a little bit when you ease off the stretching tension on it. No biggie though... I imagine if you got it all stretched and stapled, if you let it sit for a while, the lycra would loosen up. I painted the resin on right away though, after stretching the fabric. The lycra was harder to stretch than the fleece, and I actually jacked up my back doing it (holding the frame steady with my feet, stretching the lycra with my left hand, and using the staple gun with my right hand simultaneously... I'm still hurtin').
It's pretty strong in certain places. The dip in the center is really strong, but the outer surfaces are stretched so tight that they're a little thin. So, I have to be careful when I'm moving it around, feels like I could put a hole through it, but it's plenty strong for me to reinforce without worrying about it.
PaulD
09-03-2002, 11:34 PM
I just had a really cool thought (they do happen once in a while) .... instead of putting speakers in that thing - have you considered putting amps or maybe a pair of EQT's in something like that ? Now THAT would be novel - and wouldn't have to be as strong.
EFsleeper
09-08-2002, 09:52 PM
looking sweet bro. keep it up. cant wait til its done!
Cyprus106
09-19-2002, 03:41 PM
That's so clean. I love it. I've been trying to figure out how to make fiberglass stuff like that for months. How'd you do it? I'd really like to know. How much does it cost? Is it hard to do?
Thanks lotz
ci5ic
09-19-2002, 05:46 PM
Thanks lotz
Well, this is really my first fiberglass project. I've done some experimenting on some scrap stuff, just to find out what works best for me... As far as how to do it, there are several different methods... What I am doing for this particular project is:
1.) Cut out the shape of the base and the mounting rings out of MDF (medium density fiberboard).
2.) Using some 1" x .5" lumber, positioned the rings above the base using hot-glue (also added some dowel rods for more support).
3.) Stretched Nylon Lycra material (fleece works also, just not as stretchy) over the frame, and stapled it (using a staple gun) to the underside of the base (Using the Lycra is only to provide a natural shape for the pod).
4.) Coat the stretched Lycra with fiberglass resin to harden it up.
5.) Re-inforce the outside with a layer of fiberglass.
6.) Remove the internal supports that I used to secure the mounting rings (provides better access to the inner surfaces).
7.) Re-inforce the inside with several (5-6) layers of fiberglass.
8.) Sand the exterior smooth (also use Bondo for a filler).
9.) Paint it yellow to match the interior. You could cover it with carpet or vinyl if you want. If you use vinyl, you need a really smooth even surface because any defects will show through. If you paint it though, you have to be REALLY REALLY anal about the defects.
Anyways, most of the materials you will need can be purchased at a boat shop (fiberglass resin, hardener, matting, bondo, etc.)
Here's some really good web-sites about fiberglass work:
http://members.iinet.net.au/~nismo/subs.html (shows step-by-step how to make a "sub-tub" in your spare tire well)
http://www.resnet.wm.edu/~bplesn/fiberglass.html (some info and links)
http://www.diysubwoofers.org/audiolinks.htm (some fiberglass related stuff)
Hope that helps.
Cyprus106
09-19-2002, 07:53 PM
Thanks TONS. I've been trying for MONTHS to figure out how they do custom fiberglass jobs and such. I thought it involved like machinery or something...
I'll see these imports roll up with a completely custom fiberglass interior and I always thought they had to pay a couple grand get the pieces and stuff like that done and I've looked EVERYWHERE trying to find out how to do the fiberglass thing.
Thanks alot. You saved me a ton of bitch work and now I've got a new project!
ci5ic
09-19-2002, 08:03 PM
Yeah. I was gonna have a local stereo shop do a bunch of fiberglass work for me, and they quoted me 2 grand for it. I was like, Fuck that! I decided that for probably less than $500 I can buy all the material and tools I'd need to do it myself. So far, I think I've spent about $300 (most of that was spent on a Dremel, Skil saw, staple gun, heat gun and other tools). So, when I finish, I'll have saved myself a ton of money, plus, I'll have the pride of knowing that I did it myself (and I'll have the tools I bought for other projects).
Cyprus106
09-23-2002, 02:34 PM
Hey, theoretically... could I do this to my whole car? I've successfully created a kickpanel and I'm getting ready to make a mold of a rear panel for customization.
Basically, I've wanted a fiberglass interior since I bought my first soupin' car but I never knew how or where I could get it until recently. If I do do a custom interior:
How many layers should I use, first of all (I've heard 7...)?
What should I paint it with, is there any specific way I need to paint this?
And how do you propose I create the clips to hold this stuff in?
Instead of molding right from the chasis, (on some parts) I'm going to mold over the panels and then dent, change and warm them as necessary. With those pieces, How should I get these new fiberglass panels to stay there? I could use the clips from the original panels I guess... or should I straight drill some new holes or something?
ci5ic
09-24-2002, 12:01 AM
That's a really tough question (for me)... I've been thinking about the same thing. It would be really easy to create fiberglass panels for my hatch, but I always seem to run up against the problem of how to secure the panels to the car... One thing I thought of was using the existing panels as kindof a base, stretching fabric over them and fiberglassing that. Then, possibly cut away the parts of the panel that I wouldn't need, leaving the clips and stuff... I dunno.
The other thing is, if you use your existing panels and fiberglass over them, you're adding a bunch of extra weight, which will harm you cars performance. Just thought I'd throw that out there in case you're concerned...
As far as what to paint the panels with, you could use spray-paint if you want. I would go with a good sandable primer, some Krylon Interior/Exterior paint, and some Rustoleum Crystal Clear Enamel...
Personally, I'm going to have my fiberglass pieces painted at a body shop with automotive paint...
Gusto222
10-07-2002, 10:11 PM
looks phat... -- do gell coat..
strodda
10-26-2002, 05:50 PM
hey ci5ic,
i noticed you were mounting your subs reversed from normal. is there a purpose for doing that? or a difference in performance? or is it just a looks thing.
PaulD
10-27-2002, 01:36 AM
it's just a looks thing ........ and the little extra space the speaker takes up is not subtracted from the box volume - since it is no longer in the box
ci5ic
10-29-2002, 09:30 PM
Haven't decided which way they'll be mounted. I'm going to try it both ways and see what sounds the best.
Man, I'm such a slacker, I still have alot of work to do on the pod, but now it's getting really cold out, I may not finish it until next spring. :(
kicker1_solo
10-29-2002, 09:48 PM
Man, I'm such a slacker, I still have alot of work to do on the pod, but now it's getting really cold out, I may not finish it until next spring. :( do one in and one out :)
and washington weather is a bitch :(
whoaitzvan
11-10-2002, 02:39 AM
wellz .. if u look at mah dash.. i ..basicly fiberglassed over mah .. center console.. so i jus used mah stock.. consle as a base.. but it took meeh a long time to figure that out.. i guess .. u live and u learn.. but it looks ok for a .. DIY job.. hehe.. the next think i need to do is to re-route my vents .. does any one know how to do dat??.. WHOAItzvan.. and mah pix is in dere..
ci5ic
11-13-2002, 07:12 PM
:huh:
mah brain.. is teh hurts ouch..
