HOW-TO: remove the front and rear panels w/pics
Google
Web AF
georgelovesdirt
09-29-2006, 03:04 PM
First get a flat head, a phillups, and a 9/32 socket.
Rears first
Remove the two screws from the front pillar cover and pull it off.
http://img475.imageshack.us/img475/4302/rearfrontpillar2uz0.jpg
Next, pop off the rear pillar cover.
http://img300.imageshack.us/img300/2140/rearrightpillarhn3.jpg
Now locate the plastic screw behind the lever and unscrew it.
http://img212.imageshack.us/img212/8976/rearleverscrewaf0.jpg
Use the flat head to carefully pop out the retainer clip so it wont get busted when your prying the plate off later.
http://img518.imageshack.us/img518/3821/rearleverscrewharnessgi2.jpg
Next carefully pop off the lever plate off...
http://img182.imageshack.us/img182/891/rearleverplateremovalyv5.jpg
... and just let it hang there.
http://img475.imageshack.us/img475/1746/rearleverplatehangingav6.jpg
Now get the flathead and pop off the cover in the handel that covers the two 9/32 screws.
http://img528.imageshack.us/img528/137/rearholdscrewcoverls1.jpg
Now remove the screws.
http://img178.imageshack.us/img178/9928/rearholdscrewrevovalqo4.jpg
Now reach inside and pull the wire harness off the window switch. it isnt clipped in, just pull it off. At this point the panel is hanging by the window slot, adjust the lever plate so that it will slide through the hole behind it, then simply slide the entire panel upwards and it will come off. make sure when you slide the lever plate through the hole you dont tear your leather.
http://img526.imageshack.us/img526/9226/reardisasembledjy3.jpg
To put it all back together hang it by thew window slot, clip the window switch back together, slide the lever plate through the hole then pop everything back together.
Now to pop the lever plate back together. First line up the lock hook to the lock switch in the plate.
http://img475.imageshack.us/img475/1267/rearleverhooklineupdr7.jpg
Now hook the top part of the plate in and then pop the bottom part in.
http://img519.imageshack.us/img519/7712/rearleverplatereasemblerk9.jpg
Check to make sure you did that part right by locking and unlocking your doors electronicly with your fob.
Now for the Fronts... pop off the lever plate panel and remove the handel screws just like the back doors.
Now pop out the instrument cluster from the front with a flat head.
http://img529.imageshack.us/img529/6043/frontclusterpopoutyq9.jpg
after you do that un-clip all the switches, some of them can be a bit tricky, be careful not to snap any plastic.
now start un-popping the panel staring with the latch side and working your way to the bottom and then the hinge side.
http://img486.imageshack.us/img486/6125/frontpopstarteo3.jpg
now slide it upwarods in the same manner as the back door. Check out all the state of the art sound dampening.... paper.
http://img529.imageshack.us/img529/6619/frontdisasembledno4.jpg
to put it back together just do the exact same thing as the back, folowed by hooking the cluster back together and poping it back into place.
Extra info: youll probably be doing this to change the speakers. on 95's the backs are 6.5'' with wizzer cones. the front 6.5'' speakers and the front 1'' tweeters in the dash are split from the same line with a crossover (somewhere). so if you are replacing the front speakers dont get ones with built in tweeters, just get normal mids. all 4 stock speakers are marked with the + or - so its easy to change them.
mszabo
09-09-2007, 03:55 PM
so how do you remove door panels when you have manual window cranks?
cardboardpimp420
11-11-2007, 01:37 PM
same basic steps, there is a little clip behind the crank that needs to come off then the crank will pull right off
BigCasino
03-12-2008, 11:54 PM
Have you ever changed the rear speakers on a 2001 2dr? If so How do you remove the rear panels?
s10blazerman4x4
03-13-2008, 12:00 AM
Ha BigCasino, Id send ya the how to I found online but I misplaced it. Lets say it won't be easy. I believe if i recall it involves removing the entire panel from rear to front. If I find it, Ill forward it to you in a PM.
Google
Web AF
