Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 09-29-2006, 10:39 AM   #1
capriceowns
capriceowns Normal reputation
Pressed and floating piston pins
What exactly do these 2 terms mean, Im looking at pistons for my stroker, I ordered a Eagle stroker crank for 1 piece seal blocks and rods, and i found the 18cc dish top keith blacks giving me 8.7:1 with my 76cc heads(thats still pump gas right?)
I can order them with a floating pin or pressed, thats what I dont get.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
capriceowns is offline   Reply With Quote
Old 09-29-2006, 11:46 AM   #2
silicon212
AF -Advisor
silicon212's Avatar
silicon212 Normal reputation
Send a message via ICQ to silicon212
Re: Pressed and floating piston pins
Pressed means the pins are pressed into the small end of the rod. Floating means the pins are retained in the pistons with snap rings and the rod is bushed so that the pin can move around in it. Of course, this means the rods have to be prepared for the floating pins.
Stock pistons are pressed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
silicon212 is offline   Reply With Quote
Old 09-29-2006, 12:04 PM   #3
bobss396
bobss396's Avatar
bobss396 Normal reputation
Send a message via AIM to bobss396
There's a lot of perceived pros and cons to both conventions. Floating pins require more parts, more machining. They can also promote piston skirt slap since you have introduced another axis of motion into the mix. Some racers use coatings on the piston skirts to combat it.
Unless this is a race-only engine, you'll be gaining little by going to floating wrist pins.
Bob
bobss396 is offline   Reply With Quote
Old 09-29-2006, 12:06 PM   #4
capriceowns
Can I still order them as pressed? even if Im not buying the rods and pistons together.
Bookmarks
Google
Web AF
