Name that connector! Pics inside..NickF829 09-28-2006, 08:41 PM Ok, so picture the harness the connects to each individual injector(3.1 v6). Attached to this harness is a large, 3 female ported connector, it is green. Attached is the pic. I can't figure out where this thing goes to save my life. Any takers? http://img.photobucket.com/albums/v605/Nickf829/connector001.jpg tractorboy 09-28-2006, 09:45 PM Ect Sensor , Iac , Egr , Map OR MAF IF THE CABLE IS LONG ENOUGH IGNITION COILS CAMSHAFT POSITION SENSOR OX SENSOR HEATED HAS THRE TERMINALS RIGHT. I THINK IT IS THE MAP NickF829 09-28-2006, 11:23 PM ok so next question, do you have a picture of the map sensor? i put everything back together, just ran that connector to the outside toward the ign. coils, now I have a (1)empty vacuum inlet, (2)a 3 prong green connector(pictured), (3) a empty mounting bracket attached to the rear upper intake bolts and (4)a tube connected to the air intake leading to this empty spot where the MAP sensor should be. so i assume i'm missing the sensor. this is what i get for walking away from this POS for 2 months before finally finishing it tractorboy 09-29-2006, 01:05 PM Yes, sounds like you are missing the MAP sensor. Do you have any parts laying around? left over ? a new one probably at auto zone or pep boys should not cost much. Don't forget a gasket too, if it needs one. A junk yard may have one also. Don't run the car with out, if it will start. NickF829 09-30-2006, 02:33 PM found it, it was in front of me the whole time on my welding bench, it didn't look like i expected though. thanks for the help tractorboy 09-30-2006, 09:20 PM glad to have helped Automotive Network, Inc., Copyright ©2012
