Front Wheel Bearing - 2000 Venture
Paul Scanzillo
09-28-2006, 05:39 PM
I have to replace the front bearing on a 2000 Venture. It appears that the spindle has to be removed and the bearing pressed at a machine shop. Is this correct? I've done this before on a Windstar and is not that big a job. Just wondering if there is something out of the ordinary with the Venture that I need to be aware of.
Thanks!
AJT1961
09-29-2006, 05:41 AM
Not correct. The front bearing is part of a sealed hub/bearing assembly that is simply replaced. They cost big bucks at the dealer (over $300), but I've had good luck with aftermarket replacements. Autozone sells them for $110 (Dynapak Wheel Bearing/Hub Assembly part number 513121 $109.99) It's not a tough job at all, but you'll probably need a large three prong gear puller to free the CV half-shaft from the hub assembly as well as a large deep socket for the axle nut (don't recall the exact size offhand). If you don't have one, I strongly recommend get yourself a Haynes manual for the van as it will save you a lot of time and headaches and pay for itself in no time.
Paul Scanzillo
10-02-2006, 06:04 PM
Thanks AJT1961 for the help. I found all this out today and it seems a rather simple fix but pretty pricee. On the Windstar, the bearing and machine shop press cost me $50, but it's a much bigger job...the entire hub has to be removed to press the bearing. Will be doing the job on Wednesday.
truc0011
10-03-2006, 01:42 PM
I just did the wheel bearing on my van, the axle nut was size 33mm if that helps.
mhall02
10-10-2006, 09:20 AM
How did this go? I'm doing my '99 Montana towards the end of this month and I have a Haynes manual and am going to use the Dynapak from Autozone. Was it hard to get to the three bolts that hold the back hub?
truc0011
10-10-2006, 09:23 AM
Its not too bad to get them lose. But if your like me and like to torque everything when you put it back together, that was a bit of a challenge.
mhall02
10-10-2006, 10:51 AM
OK, thanks, so basically after removing the caliper and caliper bracket, I need to pull the three bolts on the back of the hub, the axle nut, and use a puller to get the bearing out and reassemble? Was there a seal that needs to be replaced as well, or just the hub/bearing? Did you use the Autozone product? Thanks again for your input!
truc0011
10-10-2006, 11:00 AM
Yes, you have the procedure down. There is no gasket. I used a genuine GM bearing, got it for Ebay for $90.
mhall02
10-10-2006, 02:56 PM
$90, good price!! Thanks again!
Paul Scanzillo
10-10-2006, 05:08 PM
I also had no problems with the job. But be sure to use a six-point socket on the 3 hub bolts. They felt like they wanted to strip but all went well. An open-end wrench or box-end wrench will not work because of interferece with the back of the hub area.
phipps
10-11-2006, 08:19 AM
Did you have to use a swivel to get a socket onto the 3 retaining bolts?
truc0011
10-19-2006, 04:48 PM
Its possible to get the socket on without a swivel.
69Charger
10-19-2006, 05:08 PM
I always find that if you separate the lower -balljoint and slide the axle back in the hub its alot easier to take out the 3 retaining bolts.. For the minute it takes me (being experienced) its worth the time saved, especially working on flat rate :D
gadan
04-27-2007, 05:52 PM
I'm ready to replace a wheel bearing on my 2000 Venture, and went to Autozone and Advanced but they don't carry 33mm socket nuts, neither Sears does. Any idea where can I get a 33 mm axle nut?
Thanks in advance.
scottnhalifax
04-27-2007, 06:22 PM
just stick a 34 mm on there, it will work, thats what we use in the shop
scott.
LMP
04-27-2007, 10:47 PM
Mine turns out at exactly 1 5/16" and this is the socket I use; that is just a little over 33mm..in fact 33.3 mm...so I believe 34mm would also do the job with a some spare clearance.
gadan
04-28-2007, 09:05 AM
Thank you guys for your help. I'll try to do the job using 34 mm axle socket. I got a the part from 1AAuto.com yesterday $ 84 plus 12 delivery, total 96. I ordered on Tuesday and got it on Friday, quick delivery and good price.
Hope everybody have a great weekend.
