'05 Corolla trans fluid changeDFBonnett 09-28-2006, 12:43 PM My daughter's fiance has an '05 which is due for a trans fluid change. When drained from the plug on the trans pan, does the differential drain also? Does the differential refill from the filler tube along with the trans like my V-6 Camry or is there a separate filler plug for the differential like some of the Camry I-4s? If there is a filler plug, do I fill until the level is even with the bottom of the filler hole like the diff on and RWD vehicle? TIA DFB DFBonnett 10-05-2006, 09:55 AM Anybody? Brian R. 10-05-2006, 11:59 AM Since no one is posting who knows for sure, I suggest you jack up the front of the car and look for yourself. If there is no fill plug or if there is one, either way your question is answered. If there is a fill plug, use it. Yes, you would fill the differential up to the bottom of the fill plug, if there is one. The differential drains separately from the transmission. DFBonnett 10-05-2006, 05:53 PM Thanks, Brian. Brian R. 10-05-2006, 06:41 PM You're welcome Automotive Network, Inc., Copyright ©2012
