95 Aurora- Which Fuse?Hesam 09-28-2006, 05:06 AM Can someone tell me which fuse to pull out to disconnect the Gas-Shock's Pressure adjustment pump that keeps going off and on everytime I sit in the car? The shock is probably leaking gas and pump is not doing it's job so it just keeps running with noise like bulldozer. Someone should tell GM engineers to Pleaseeeeeeeeeee not get too high-tech. When your High-tech 4-coil-pack system or your shock-pressure-adjustment-pumps get old they cost us arms and legs.:nono: It's like women's skin. When it's normal at youth, it stays straight in old age, and when it's too soft and silky at youth it gets wrinkled at old age. Instead of adding all those worthless gadgets, just put a lighter 280HP engine in Aurora and reduce this car's weight by 500 pounds by taking off 10 inches from the length.:screwy: newscarver 09-28-2006, 07:33 PM yeah....its one of the ones under the back seat...according to the manual its in the passanger side box of fuses the reference is elc for electronic level control... the map is inside the lid of the fuse box Automotive Network, Inc., Copyright ©2012
