'90 accord EXR tranny problems
n2o4ever
09-25-2006, 03:38 PM
When I park my car and shift into park (automatic) the dash light (P) doesnt light up and the car wont release my keys.
somick
09-26-2006, 03:13 PM
Try to jiggle the lever and make sure it is exactly in Park.
Sam
n2o4ever
09-28-2006, 09:02 PM
yah everytime i turn the car off i have to jiggle it for it to release the key
n2o4ever
10-19-2006, 03:03 PM
anyone?
AccordCodger
10-19-2006, 06:27 PM
Wear in the solenoid actuation mechanism. Pull the console out and take a look what's happening.
mpumas
10-20-2006, 02:01 AM
This has been covered many times. The problem may be the gear shifter position switch located on the left side of the shifter under the center console cover. A varrnish builds up on the P contact which is all the way forward.. You need clean the contacts on the slider using with thinner and very fine emery paper. Then coat with a light grease. You can disassemble the switch without removing it from the console. Before reassembling, make sure the P ligths when in Park with the key on.
n2o4ever
10-20-2006, 03:27 PM
could someone tell me how to disensemble it?
93hase
10-20-2006, 06:33 PM
There are a few screws on the side, it should lift right out.
AccordCodger
10-20-2006, 06:56 PM
But if you are not comfortable removing the console without precise instructions, you would probably be best leaving the shifter and related assemblies alone.
n2o4ever
10-21-2006, 06:32 PM
thats what i was thinking, is it a hard project or is it easy
