horn relaysevenkjg 09-25-2006, 03:00 PM having trouble locating the horn relay in a 1992 chevy cavalier, any help appreciated. Lances133 09-25-2006, 03:54 PM I've tried searching on www.v6z24.com and I got a few possibilities, they're all from like 89s, 90s, or 91s but I'm assuming they gotta be the same right? Oh well I tried, here's some areas you could search... 1) "Not sure if it's different on the earlyer cars. But on mine its on the left side under the dash near where you put your left foot... Look under there and the one closest to your face (bottom towards pass side... it's white most likely) pull that out and then search the part number on the net" 2) "its back behind the fuses i believe atleas theres a little button electrical thingy that looks for the horn" - ? I dont really understand what he was saying there lol 3) "It's beside the hazard flasher. Both are located above the driver kick panel on teh firewall, where the "door dinger" is. Open the door with the key in the ignition, or turn the parking lights on, without the key being on and follow the sound. The horn relay is a small green cube. It has 3 prongs on it, once you pull it out." sevenkjg 09-25-2006, 08:27 PM Thanks for the help, removed two screws from the kick panel and pulled it down, and there was the horn relay. Thanks again! Lances133 09-25-2006, 08:28 PM Ha, awesome. Automotive Network, Inc., Copyright ©2012
