Defrost Only on 1992 Lumina APVscarmack 09-24-2006, 12:33 PM Hello No matter what you want AC, vent or Bilevel the AC or heat only blows out the defrost no where else help me please Steve richtazz 10-08-2006, 10:39 PM firts check the vacuum line from the intake to the HVAC system for cracks/disconnected. the system will default to defrost/floor when no vacuum is present. If you have vacuum, then the actuator for the defrost mode is stuck. tomcat0813 07-30-2009, 12:12 PM check vacuum control valve assy under right hand dash. Check for 12 volts on purple wire if there remove control vlve assy and take off cover . inspect printed circuit to valve body conections. Automotive Network, Inc., Copyright ©2012
