qwik questionpaintbusta 09-23-2006, 11:14 PM ok ive got a 96 4 cylinder automatic contour it wont start when it tries it sound like a metal on metal grinding noise the belts turn so its not locked up but i dont know wuts wrong ive already replaced the spark plugs/wires air filter and battery any hel would be greatly appreciated also i wuz wondering if i could swap it with a ford focus motor if i couldnt get it runnig or can i put focus motor parts on my contour motor?? lestro 09-25-2006, 07:27 PM ok ive got a 96 4 cylinder automatic contour it wont start when it tries it sound like a metal on metal grinding noise the belts turn so its not locked up but i dont know wuts wrong ive already replaced the spark plugs/wires air filter and battery any hel would be greatly appreciated also i wuz wondering if i could swap it with a ford focus motor if i couldnt get it runnig or can i put focus motor parts on my contour motor?? does the belts turn when you try to start it?, if so remove the serpentine belt and see if it still grinds, if so check flex plate to starter, then internal engine bearings. I had a broken flex plate paintbusta 09-25-2006, 09:48 PM thanks lestro for the advice havnt tried it out yet prolly tommorow but any answer on the focus parts?? KimMG 09-27-2006, 01:15 AM Is it the starter that is grinding? Automotive Network, Inc., Copyright ©2012
