Problemsandyram78 09-23-2006, 09:52 PM I have a 99 Cavalier Z-24 that all of sudden won't start for me. When I try to start it nothing happens. The car won't turn over, radio won't turn on, power windows won't work, wipers won't work, most doesn't work. The lights and power locks and hazard lights still work but nothing else. Battery is good so I can't figure out what could be wrong with it. I have tried to use a code reader but I keep getting a "link error". Anyone know what could be causing this. Car was running perfect then I parked it for the nite and it wouldn't crank after that. Please help I am in a bind... Crazzzyj 09-23-2006, 11:10 PM Makes you wonder if someone put something in your gas tank, like moth balls, the night before. ~Crazzzyj andyram78 09-23-2006, 11:13 PM what would moth balls have to do with me losing power to everything Classicrocjunkie 09-24-2006, 12:35 AM Sounds like a dying battery to me. If its the original battery 10-1 its dead. Mine died in my 99 over last winter from no use. Check all your fuses, connections, grounds you can find. Crazzzyj 09-24-2006, 08:48 AM what would moth balls have to do with me losing power to everything They would weld your pistons together. :shakehead ~Crazzzyj Lances133 09-24-2006, 08:59 AM lol are you serious? I'm putting a lock on my gas tank door ASAP:lol: andyram78 09-24-2006, 11:25 AM but why wouldn't my radio, windows or pretty much anything else electrical work except lights and doorlocks if pistons are welded. Derk_eliso 09-24-2006, 06:35 PM I agree with Cody, sounds like a battery. My friend's Focus died on her and her lights and radio and stuff still worked...It was her battery. andyram78 09-25-2006, 08:26 PM well i checked my battery and it turned out bad put a new one in and still not working. For those who don't understand the only thing that works on the car is the power locks, and lights. The chime when door is open works but sounds like crap. My radio won't turn on, blinkers won't work, car won't start and power windows won't work. Does anyone have an idea what could be wrong with it. Please advise I am desperate Lances133 09-25-2006, 08:30 PM I have no idea but, alternator? :dunno: andyram78 09-25-2006, 09:48 PM would an alternator keep everything from working even though the battery is fully charged and brand new MrR0b0t0 09-25-2006, 10:14 PM yeah, im pretty sure its what supplies most of the power, I think thats after its started tho. Im not sure, but its worth a try. djmoore85 09-25-2006, 10:19 PM I'd say check all fuses and relays starting at the main box under the hood. If electricity is getting to minimal things and not others on top of getting weak current to the things that are working, I would imagine a possible bad ground or fuse/relay malfunction somewhere, considering the batery is brand new. When I had my Wrangler, there was a paper thin (looked like tissue paper when I cleaned it off) build-up of corrosion on the negative battery post, and that prevented the whole vehicle from getting enough juice to crank. I'm always surprised when the smallest things in an electrical system can cause problems. Just my :2cents: andyram78 09-26-2006, 08:29 PM anyone have an online manuel for a 99 cavalier 355smallblock 09-26-2006, 08:38 PM Check For A Bad Connection At The Battery Ground At The Engine Not The Battery!!! Automotive Network, Inc., Copyright ©2012
