1989 plymouth colt
Hatedodges
09-20-2006, 11:32 PM
I have a 89 colt 1.5L that runs, but it will just out of the blue, not start.. it will start and run every day then for 2-3 days run when your first start it... then you shut it off and it wont start for a few hours... very weird... it also has a rough idle and the check engine light comes on after a few mins of running... I have tried to get the fault codes on it but schucks doesn't have a scanner that will work for it... they said its under the hood.. but from what I have found its under the dash..... I also have another ECM from a wrecking yard and that doesn't change any of the problems in any way.. so I don't feel that is my problem... when it wont start the spark is a dull gray instead of the bright white... and it seemed to be able to push start it... so confused.....
typesix
09-21-2006, 08:54 PM
You may want to check in at the Mitsubishi forum since this was built by them and Chrysler rebadged it.
