Car Flexible Neon Wire (kpt Series)ciomp 09-20-2006, 06:11 PM FLEXIBLE NEON WIRE (KPT SERIES) Flexible Neon Wire, also called Electroluminescent (EL ) Wire is the new generation product in global lighting and display industry. Wrapped by colorful plastic tube on its surface, it appears similar to common phone wire, emitting light along its entire length but without any heat radiation. It consumes much lower power, just 50-70% of LED lamp, 20-40%,rope lamp and 1-10% neon light. APPLICATION FIELDS Indoor and outdoor Advertisement: written pattern for display window, door, furniture, wall, ceiling etc. 2. Vehicle decoration: Internal and external car, ship etc., instrument, meter or data display. 3. Safety sign and indication: Street, stairway, corridor, doorplate, exit and outdoor temporary danger zone etc. 4. Toys, arts an crafts, sports items, clothing, electrical appliance, military equipments etc. Characteristic: 1) Homogeneous light along the entire length with wide range of vivid color, great and comfortable to be seen especially in darkness for both human being and animal, also no influence on growth of plants. It’s clear and safe to be observed in distance at night when it’s been equipped on car door outline. It also can beauty the city night scene when applied on tree, grass etc. 2) With characteristic of energy saving, environmental protection as well as safety, it has low power consumption, applied to voltage from 3V to 220V, also no heat radiation, can save national electric power sources greatly. As per present suitable application in indoor or outdoor low building , it’s able to save 15% darkness decoration power in cities. And decrease environmental temperature efficiently. It will not cause any environmental pollution whatever usage or be abandoned, especially can avoid serious lighting pollution in big cities. Due to its low working current , it has no harm to human body. 3) It’s flexible, can be bent , knotted, cut , stretched, spliced etc. but lighting effect will not be influenced . Flexibility of EL wire is similar to common phone wire, folding angle reach more than 15 degree, maximum bending achieve 360 degree, and can be bent or stretched repeatedly . The length of EL wire is cut according to customer’s application but the homogenous lighting effect remain still the same. 4) it come into continuous lighting length , featured in 360 degree multi color lighting, be made single color or combination of different colors on one single wire, animation effect is achieved by circuit control. It has different shape such as squareness, round, half round, flat etc. Single luminescence core or more luminescence cores is able to be combined to improve the brightness. Diameter arrange from 0.7 to 20mm or even bigger. 5) To be fixed on decoration surface with transparent adhesive tape, glue, clip, thread nail, or plastic card etc. decoration surface include glass, display window, furniture, window, wall etc. It’s easy to be applied, no need of any professional instruction. Flat EL wire can also to be sewed on cloth, leather etc. Diameter: 1.2, 2.0, 3.0, 4.0, 5.0MM Color: Red, Blue, Green, Lime Green, Orange, Transparent(clear), White Shape: Round, Square, Flat, Double color, Three-color Maximum length:100m Operation Current: 6 mA/m , Power 0.4 W/m Capacitance 4.6nF/M, Anti pulling ability < 1 KG Brightness: 30-100Cd/m2 Wire working condition: AC 80-150V 50-4000HZ Optimal wire working condition : AC 110V 1000-2000HZ Customer’s usual application condition:AC220,AC110,DC3V,DC6V,DC12V,DC24V Environmental temperature: –40 - 60 ℃ Average application lifetime: 3000-5000 hrs As per special requirements, pls. place a order in advance. Assistant product 1. Waterproof connector Ф1.5X4.0(cm), non Waterproof connector 2.Fastness Plastic adhesive card, size: 2.5X1.5X1.0(cm), white color 3.Glue: Ф1.7X5.0(cm) Qty: 3ml 4.White color plastic fastness tape 5.Power Adaptor (mainly use together with DC driver), size:6.0X7.0X5.0(cm),Current:500-800mA, AC110-220V (Input) transfer to DC12V(output) Weight: 270-300g 6. Multi connectors MATTERS NEEDING ATTENTION: 1. EL wire are prohibited to be joined with household outlet directly without inverter’s connection. 2. Animation mode is achieved by controlling driver circuit 1. EL wire are not allowed to be cut under the electric working condition, electrode in the cutting joint may have short circuit, keep the joint sealed and waterproof. 2. Try to avoid EL wire being bent, folded or stretched repeatedly when during installation. 5. Different length of EL wire should be matched with appropriate drivers, otherwise drivers would be damaged thus causing danger. Rough transportation may injure the product, turn off the power immediately and return it back to suppliers when EL wire been found heat. Keep corrosive and flammable items away from product application environment to avoid unexpected danger. Instructions should be given by professionals during installation. *Danger would arise, inverter and EL wire would also be damaged if violating the above warning, SHANGHAI KEYAN PHOSPHOR TECHNOLOGY CO.,LTD (KPT) ADD: #139, No. 3740, Huaning Rd., Xinzhuang Ind. Zone., Shanghai, 201108, China TEL: +86-21-64422503 64896229 64898133 64898135 13311868228 FAX: +86-21-64898169, 68540461 E-MAIL: zhengzl@public.cc.jl.cn (zhengzl@public.cc.jl.cn) or kpt@kpt.net.cn (kpt@kpt.net.cn) HTTP://www.kpt.net.cn (http://www.kpt.net.cn/) http:// ciomp.diytrade.com (http://ciomp.diytrade.com/) Automotive Network, Inc., Copyright ©2012
