unknown stalling problem
chevyguy93
09-20-2006, 05:49 PM
Sofar this car has been great to me. Today i drove a short distance to a store. As i was pulling out, there is a steep ramp you have to go down. I stopped on the ramp to check for cars coming, and the car stalled. I put it in park, started it back up, and drove away fine. I didnt really think anything about it. I figured it was just because i was sitting on a steep decline.
A few hours ago I pulled into a parking lot, turned around a corner, and slowed down to let a car pass. The car then seemed to rev up a bit, then slow right down, then rev back up. Even with my foot on the brake, the car shook a bit and moved forward. This has got me really puzzled, and I cannot figure the problem out. I know its not the solenoid in the transmission because I just replaced it a few months ago. And it happens when in first or second gear.
Its a 93, 4cyl. Any suggestions?
Cavalier2000
09-20-2006, 06:04 PM
how is your fuel filter
chevyguy93
09-20-2006, 06:21 PM
fuel filter is good. i just replaced it in the middle of summer.
chevyguy93
09-20-2006, 09:46 PM
Okay, i did some searching and ive come up with a few things from this forum. Let me know if I should do check these things or replace them
1. spark plug wires - possibly arking?
2. egr valve?
3. tps or map sensor ?
chevyguy93
09-21-2006, 03:26 PM
ok so it happened again today. was parallel parking, and when in drive with the brakes on, the engines rpms went up a bit, the car lurched forward, and the rpms dropped as if it was going to stall, then came back up. whats causing this?
Cavalier2000
09-21-2006, 05:44 PM
tps maybe? does it feel like it is "surging"
booyeanoskie
09-22-2006, 10:05 AM
Clean up the throttle cable, maybe it's sticking. Other than that, it might be EGR related. Also, check your battery/alternator.
chevyguy93
09-22-2006, 12:31 PM
I guess you can describe it as a surging. I took the tps off yesterday and looked at it and the wires, it seemed okay. And I dont think its the throttle cable sticking. I will check that after though to make sure. My alternator was bought last year, so its fairly new, same with the battery. I have been having problems with the battery, the post broke. So every now and then you have to wiggle the cable to get it started. But that shouldnt affect it much, since the car can run without the battery when its started.
And another thing. A few days ago i noticed a squeaking noise coming from under the hood. Today I took a look, but couldnt determine exactly what was making it. It is coming from the side where the belt is. it goes 'squeak squeak squeak'. Maybe is it the water pump? Is it perhaps seizing? and then slowing down the belt and stalling the car?
Cavalier2000
09-22-2006, 12:48 PM
or a bad belt, and change that battery, if you run with the battery off too much you blow your alt, damn new school. some of the touchy alt's as soon as it is rrunning and you pull the battery, you blow the alt.
chevyguy93
09-22-2006, 03:58 PM
really?
Well. i bought this battery last year from canadian tire (which now i regret) for around 100$ canadian. Its the top of the line one. During the winter, i went to start my car and nothing happened. I heard my alarm module clicking, which didnt make sense. So days went by and i had the car ripped apart trying to find the problem, because it was as if something was shorting out. My dad happened to jiggle some wires under the hood that lead to the battery, and the lights started flickering. We then saw that the post on the battery was broken, and it was wobbling. My dad then did something to help it a bit, but every now and then I have to get out and wiggle the cable to start it.
I got the extended warranty, so all i have to do is take it back and they will give me another one. Do you think this would solve my problem though?
P.S. dont buy canadian tire batteries. My grandpa has even gone through 4 within the past year because they wont stay charged.
alpine1
09-22-2006, 04:36 PM
i believe that car has mass air flow sensor it could be going bad had that happen with my pontiac 6000 ste and another cavalier
chevyguy93
09-22-2006, 04:53 PM
It doesnt have a mass air-flow sensor. Well, not that i know of.
Cavalier2000
09-22-2006, 04:56 PM
yea trade in that battery, though i don't think that is your problem, but it's not good
alpine1
09-22-2006, 04:57 PM
does the computer give any codes ?
chevyguy93
09-22-2006, 05:20 PM
no it doesnt unfortunately. Through all the problems i've had, my check engine light has never come on... which sucks when it comes to finding the problem. The only time my light came on was when I was under the hood and forgot to plug back in an oxygen sensor.
chevyguy93
09-25-2006, 08:26 PM
okay so it happened again, and I have more information.
After a long drive, i parked. 15 minutes later i started back up, put it into reverse, and the rpms dropped, and then raised. and it was very unstable, and the rpms were up and down. I managed to back up without stalling, and put it into drive and pressed the gas. After that, the idle was high. I didnt have to step on the gas at all. It stayed like that for the whole drive. Any suggestions?
alpine1
09-25-2006, 09:17 PM
do you have an aftermarket cruise control? or a remote start?if so disconnect them and see if it still happens?If that doesn't do it try the tps sensor even spray the throttle cable with some oil
see if that works
chevyguy93
09-26-2006, 01:38 AM
i have both. Its not the remote start because the starter isnt kicking in or anything... And i dont think its the cruise control because when the switch is off, it gets no power. I think it has something to do with a sensor itself. And I dont think it has to do with the throttle cable either. =/
chevyguy93
09-29-2006, 11:11 AM
no suggestions? :(
jhnsnjohn
10-02-2006, 09:38 PM
it may be a guess on my part but i wouldnt rule it out...check your injectors to see what kind of ohms they are pulling...using the ohm meter each one should ohm out to around 12.0-12.3, lower is alright but higher means that it is not working as it should...mine did that for a short period of only 1 week and it took me 2.5 weeks to figure it out :banghead: with the help of a local mechanic...its not hard to do and not very time consuming so i would check so that you could rule that out
TewSmooth18
10-05-2006, 04:47 PM
I had a car that was doing that. It wasent a cavalier but it was a Honda Civic. The problem that it was, was the Engine Coolant Tempature Sensor. So take a look at that and see if it is faulty. Once I replaced mine didn't have anymore problems with it.
Hope this helps
