Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 09-19-2006, 06:25 AM   #1
SamNovice
SamNovice Normal reputation
Cruise Control
Hello,
I have 98 Windstar and the cruise control is not working anymore. I like to try to fix it before taking it to a dealer ($$$). Are there some test I can try to find out what is wrong with this?
I tried to find the fuse but could not locate it in the manual. It must have different name.
SamNovice is offline   Reply With Quote
Old 09-19-2006, 11:39 AM   #2
radimus
radimus Normal reputation
Re: Cruise Control
Which manual are you talking about? A Chilton or Haynes manual or the Ford manual. If the former then go here and download the 98 Ford truck ISO and make the CD:
http://www.fordcds.com/
There should be a set of troubleshooting steps there for this problem.
radimus is offline   Reply With Quote
Old 09-19-2006, 09:48 PM   #3
wiswind
wiswind Normal reputation
Re: Cruise Control
The most common cause for cruise control to not work is the brake pressure switch.
The Brake Pressure switch is located on the bottom of the brake master cylinder......has wires going to it.
It leaks some brake fluid, and fails.
If yours is even slightly damp.....I would replace it.
You can get a replacement "kit" at your dealership.....they are pretty cheap......about $20 or so.
I have pictures of the replacement of this part on my '96 3.8L in the pictures that the link in my signature will take you to.
1996 3.8L Windstar
Link to my pictures, intended as an aid, not a replacement for, a good repair manual. http://community.webshots.com/album/201931518cScpNK
wiswind is offline   Reply With Quote
Old 09-20-2006, 09:30 PM   #4
SamNovice
Re: Cruise Control
Ok, it seems not bad. I'll try over the weekends. Thanks.
(The manual I refered to was the manual came with the car.)
Old 09-21-2006, 01:42 AM   #5
carvillegas
carvillegas Normal reputation
Re: Cruise Control
I have the same problem (stil is leaking, I will fix it tomorrow) , the leaking is coming from the sensor under the master cilinder, but it took me a while to find out the source of the leak (I never checked if the cruise control was working). It is a shame that we can not place pictures in this forum to show you the leaking sensor. Thank you for the advise, I will replace this sensor. (if you want the picture, send me a message).
I have a question, After replacing the sensor, Do I have to perform another step like purging the system to get rid of any trapped air into the system? How do I do that? Is there any other advise on changing this sensor? I will appreciate your help.
Jaime
carvillegas is offline   Reply With Quote
Old 09-21-2006, 06:57 AM   #6
12Ounce
12Ounce Normal reputation
Re: Cruise Control
You will not have to do any purging or anything like that after replacing the brake pressure sensor ... only a couple of additional drops will come out ... a little top-off may be needed, but not much.
12Ounce is offline   Reply With Quote
Bookmarks
Google
Web AF
