Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > N2O/Turbo/Superchargers
N2O/Turbo/Superchargers Tech forum to assist in Honda/Acura Performance.
Old 09-19-2006, 05:43 AM   #1
mads2000
mads2000 Normal reputation
supercharger oil pressure
can any one tel me i have a comptech s/c on my s2000 .oil seems to seep out of the intake side,QUITE A BIT I MIGHT ADD . what is the engine oil pressure and the s/c oil pressure . are they the same ,maybe i need a oil pressure regulator between the two. is there a seal kit . any ideas . thanks
e maIL ME OR POST IT 27829457858@VODAMAIL.CO.ZA
mads2000 is offline   Reply With Quote
Old 09-19-2006, 08:55 AM   #2
Schister66
AF -Advisor
Schister66's Avatar
Schister66 Normal reputation
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: supercharger oil pressure
what size feed line are you using? I know that on my turbo i have to run a -3an line w/o a restrictor (55psi) and that's just fine. One thing i would recommend is checking the return line to the pan. If it is kinked or loops back up away from the ground, its a bad line. It needs to drain down and into the pan. I had that problem with my turbo for a while, but then i fixed it....
The new build is underway...
Borg Warner S256 + 9.8:1 built GSR + E85 = 450whp Daily Driver
Schister66 is offline   Reply With Quote
Bookmarks
Google
Web AF
