Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 09-18-2006, 10:16 PM   #1
krohn211
krohn211 Normal reputation
Question 96 Cavalier gas smell, no noticable leak...
We have a cavalier that has a gas smell with no noticable leak. The gas mileage has been about normal but the smell of gas is worrisome. Any ideas on why it might smell like gas? Thanks.
krohn211 is offline   Reply With Quote
Old 09-18-2006, 11:39 PM   #2
G0ldRush
G0ldRush's Avatar
G0ldRush Normal reputation
Re: 96 Cavalier gas smell, no noticable leak...
It's probaly a leaking Oring from one of the injector, if the gas smell only noticible in engine running that's the problem, otherwise leak could come from gas steel pipe rusting!!!
If they don't have it, I don't need It!
G0ldRush is offline   Reply With Quote
Old 09-19-2006, 07:34 AM   #3
mike2004tct
mike2004tct's Avatar
mike2004tct Normal reputation
Might be an overflowing charcoal cannister. It's located in the right fender well in fornt of the tire. This is part of the emmissions system that recirculates unused gas and gas vapors.
It's my opinion, don't take it personal.
'04 T&C, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
mike2004tct is offline   Reply With Quote
Old 03-26-2007, 05:07 PM   #4
spyidy
spyidy Normal reputation
your gas tank might be rotten, mine rotted out on the top and i had to replace it. 1998 z24.
spyidy is offline   Reply With Quote
Old 03-28-2007, 05:28 PM   #5
nightflyr
nightflyr Normal reputation
I'm going thru a similar thing (ref my post same page). The gas smell is very noticeable (at times) while stopped, and disappears at highway speeds. I have one injector that shows signs of a leak since dirt has collected around this one injector. However, the auto mechanic (took it to local shop) says he doesn't think the injector is the problem, nor can he find it. I told him to keep the car a day and run an errand with it, the gas smell will be quite obvious.
I think it is the injector, but i'll keep you posted on what he finds.
nightflyr is offline   Reply With Quote
Old 03-28-2007, 09:27 PM   #6
DeCiX
DeCiX Normal reputation
had this same problem, it was our fuel injectors. hope this helps.
do it yourself please.....my parents did it, cost us freaking $1500, and they blew out my serpintine belt in the process we think.
DeCiX is offline   Reply With Quote
Old 03-28-2007, 11:32 PM   #7
shakewell
shakewell Normal reputation
My 97 2.4 just started doing this today. I think it's either the fitting at the fuel rail or the fuel pressure regulator. My plan, and what you guys might want to do, is to spray some brake clean (or something similar that will dry it out) around the suspect area to totally dry them out. Run it for a time and check where it gets wet.
shakewell is offline   Reply With Quote
Bookmarks
Google
Web AF
