2001 Plymouth Neon strutsTPyles 09-18-2006, 03:18 PM I have a 2001 Neon that sits very low in the front, the air dam is only a couple of inches of the ground. Wouls completely worn out front struts cause this? Thanks for your help!! das2123 09-18-2006, 03:38 PM Worn struts and springs will lower the car somewhat. Get some new springs and see if it helps. yale329 09-20-2006, 09:32 AM I would say the same, either, probably one or both springs are weak or broken. If you push down on your front end on both sides, one at a time, the front side you are testing should bounce back no more then a couple of times. Check for leaks around your strut. Automotive Network, Inc., Copyright ©2012
