91 escort wont startsnmsprick 09-17-2006, 05:01 PM 91 escort lx 1.9 turns over but wont start i have no gauge lights ,power belts.turn signals or fuel pump all fues are good battery is good. not sure where all fuesable links are located or if thats even the problem can any one please help me out. p.s fuel pump is good. mightymoose_22 09-17-2006, 11:13 PM If you investigate the no dash lights problem you may solve the no start problem. Was any work recently done prior to having this problem? Try a hotwire start to take the ignition switch out of the loop. Make sure the crank sensor is plugged in. Davescort97 09-18-2006, 12:49 AM The timing ring the crank sensor picks up on may be out of time. I had a 94 the aluminum colored ring with teeth on it behind the crank pulley had separated from the pulley causing the timing to be off. Check it to see if the crank pulley is in line with the belt. If not, that's the problem. Automotive Network, Inc., Copyright ©2012
