wheels and tireslingus 08-30-2002, 03:46 PM I am running stock 01SE and willl crank the torsion bars. Want to put super swampers SSR on, What size is best??? I want the biggest with only trimming , no lift. I also want the widest tire allowed. I want them to stick out of the body a little to save the body from damage in deep ruts. I would also look at changing rims if necessary to a wider rim. Any suggestions???? Please help Schludwiller 08-30-2002, 05:09 PM 31x10.5x15 SSR's. They run large 31.5" in diameter actually. The three stage lugs will give you LOTS of rubbing issues if you go larger without a lift. Even the 31's will rub your fuel line cover, but it's not that big of a deal. You'll also might bottom out on the front tires sometimes if you don't upgrade shocks and torsion bars. The T-bar lift might be ok, though. Just depends how worn they are. Automotive Network, Inc., Copyright ©2012
