I have a few small spots where rust has begun to appear mainly along the bottom of the doors. I was wondering if getting wax on/near these spots would help, harm, or have no effect on the spread of the rust. Any thoughts? as you can see, it's really bad. In this spot, it's actually rusted through the metal. I generally try to avoid getting wax near these spots, and dry them as quickly as possible. Any suggestions?
it just would not have any effect for at least one reason i know of: rust is not any where near smooth so how can you get a layer wax on it . just go to autozone get a rust stop crap and apply it.
Not really sure if that is even possible to save. If its just surface rust, or paint bubbling becuase of rust, you can probably save it with the rust stopping stuff. Best thing I can think of is knock off all rust and then sand down the good metal and patch with Bondo.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
thanks for the info!! The rust in the picture has gone all the way through--I can stick my finger through if I wanted to. It is the rocker panel, so can I "cut" out all the affected area, clean it up, fill with bondo, and primer/paint?? Thanks again!!
Bondo is most definitely not the answer. It will look better....for a while. The rust will begin popping back through and spreading quickly. You need to cut that area out and weld in a patch. Then smooth out the metal with filler. Filler is not a rust preventive nor does it provide strength. Patch, smooth, prime, paint. It is much more complicated than that but those are the basics. There is always much more rust than is apparent, so beware. All you see is the tip of the iceberg. Good luck.
Grant
Grant
I thought I was ready to try using bondo...I guess not! That sounds like a job for someone a little more experience than what little knowledge I possess! Would I have to have the whole panel sanded and repainted or could I just have the "affected area" reworked??
