One major leak on the drivers side of the motor could be a very simple fix. Check the oil filter cap sealing ring. If you have not changed it in a while it will produce a massive leak. Change the oil filter and ring and you might kill the leak. If not where is the oil leaking under the engine? Drivers side? Pass side?
