Neon Dome Light
wvdad
09-12-2006, 01:43 AM
Help!!!!! My 2000 Dodge Neon Dome Light And Trunk Light Will Not Work.
All Fuses Are Good And Lights Are Good Also.cant Figure This One Out.thanks
Bear
09-14-2006, 10:15 PM
Check your door light switch ( the one that is located in door jamb and controls the dme light) and see if it is stuck or not getting power. I had this problem with my '96 Caravan on passenger side, and the door switch was bad, I removed switch, cleaned contacts and ground and now she works
wvdad
09-14-2006, 10:25 PM
thanks i will try that and let you know
m78jo
09-14-2006, 11:31 PM
Mine did the same. mine was the fuses located by the engine. did you check those fuses also? I never knew there was two spots where the fuses were located.
