Keep snapping passenger side axles on 96 accord ?marc96accord 09-11-2006, 04:32 PM I had no problem replacing the drivers side but or the passenger side but when i drive it it breaks the axle any suggestions ? jeffcoslacker 09-11-2006, 05:28 PM All I can think of is you aren't getting them fully seated in the hub, and are touquing them down in a bind, or you are allowing the inner joint to fall apart when installing...they have to be kept in compression or the balls will fall out of place... Where are they breaking at? marc96accord 09-11-2006, 08:28 PM it breaks where it goes in the trans sometimes when i put it in and drive the abs light comes on then usally it breaks soon after jeffcoslacker 09-11-2006, 08:54 PM Any vibration/binding before it blows? marc96accord 09-11-2006, 11:13 PM no it dosent go in as easy as the other side jeffcoslacker 09-12-2006, 03:33 AM So it shears the inner joint when it breaks? Does the car move at all, or it breaks right away when you try to drive? marc96accord 09-12-2006, 08:16 PM first when I drive the ABS light comes on just on that alone I know the axles must not be in right then a mile or two later it I guess something make it break the joint near the trans jeffcoslacker 09-13-2006, 09:17 AM first when I drive the ABS light comes on just on that alone I know the axles must not be in right then a mile or two later it I guess something make it break the joint near the trans Well it would seem the ABS light is trying to tell you that you have a discrepancy in wheel speeds in front (unless you damaged the sensor somehow during this)...if that's the case, I'd think you gotta feel it binding or hear that wheel cutting rubber. After installing, you try spinning the wheel/shaft in nuetral and see if it's free turning? If not, try turning it with the shaft out, make sure you don't have a destroyed hub bearing that's not turning or something...I don't know, this is kinda baffling...I had a customer once who had tried replacing the axles in his CRX a couple of times and broke them, turned out they were giving him the wrong axle for one side.... marc96accord 09-14-2006, 12:15 AM yea I tried a few different axles that didnt fit but I think there's some small thing im misssing this axle now I had to take off the wholw spindle and put it in the trans first then put the spindle/hub on the driver side was no where near that hard marc96accord 09-16-2006, 08:17 PM yea they were giving me the wrong axles fixed that last night but now my steering rack or outer ties rods are now bad when I turn i heard and feel a loud clicking sound Automotive Network, Inc., Copyright ©2012
