sudden power loss - 2001tedzbug 09-11-2006, 01:10 PM my sportage is a 2001 w/ 85k miles and just lost a large amount of power out of the blue this morning...... I have not done the timing belt yet. i was thinking that, But it runs up to high rpm fine when in neutral and also shifting...... It takes forever to shift and feels like it is maybe not locking up the torque convertor......? went and got a code scan: P0650 MIL Control Circuit Malfunction P0128 Coolant Temp Below Thermostat Regulating Temp tedzbug 09-12-2006, 09:03 AM Is there a way to check the timing too see if it jumped a tooth?? other than disassembly to replace it anyways? ted tedzbug 09-13-2006, 09:04 PM replaced both thermostat sensors, air filter, fuel filter. same problem. Going to check timing belt tomorrow if not raining....... Also thinking of cat convertor being pluggged..... might try to tear into that too.... ugh ted tedzbug 09-16-2006, 08:07 PM Not so busy a forum i guess...... Anyways, it was the timing. The belt jumped two teeth. All better now scoobytuff 09-18-2006, 09:08 AM you lucked out on the timing belt not being off any morre than that. Much more and you would have bent some valves! tedzbug 09-18-2006, 09:27 AM you've got me lost....everything i've read on this forums said this is a non-interference engine.... wouldnt happen Automotive Network, Inc., Copyright ©2012
