2001 windstar o/d won't disabledbarton3 09-08-2006, 01:30 PM My 2001 Winstar SE has a switch to disable overdrive. It no longer works. I tow my camper with this vehicle. Has anyone seen this problem and if so, where should I start? I have not dug into it yet but I will look into obvious things first (ie. fuses, connections). Any help will be appreciated. DRW1000 09-08-2006, 07:59 PM My 2001 Winstar SE has a switch to disable overdrive. It no longer works. I tow my camper with this vehicle. Has anyone seen this problem and if so, where should I start? I have not dug into it yet but I will look into obvious things first (ie. fuses, connections). Any help will be appreciated. My 99 has a pushbutton switch at the tip of the gear shift lever. First thing I would check is the operation of this switch. dbarton3 05-12-2007, 01:59 PM My 99 has a pushbutton switch at the tip of the gear shift lever. First thing I would check is the operation of this switch. I've checked the switch and it is ok. Would a burned out bulb in the dash cause the function to not work at all? Automotive Network, Inc., Copyright ©2012
