Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 09-07-2006, 07:04 PM   #1
MikePathfinder2001
MikePathfinder2001 Normal reputation
Fluid in Vacuum Resevoir
Hi everyone,
When I replaced my hood, I noticed that the vacuum resevoir (I think that is what it is) was filled half way with fluid. I quickley realized it was Transmission fluid. When I refer to the vacuum resevoir, I'm talking about the black ball that has a vacuum hose hooked into it and is connected to the hood on the driver side of the car. Anyway, I'm guessing the fluid came from a leaky vacuum switch located in the transfer case. It may have been collecting in the vacuum resevoir and my 4 wheel drive actuator under the battery (which I replaced becase it had rotted through). Anyway, now I do not seem to have any heat. The fan in the car seems to blow at the correct speeds and out the correct passageways, but It only seems to be one temperature (outside air temp). I'm wondering if fluid was collecting somewhere else and causing this problem. Maybe it is unrelated because I have noticed that this car has always had a hard time heating up inside. Winter will be here in a bit and I will be out in the cold if I don't figure this mess out. Anyway, I would love to hear some possible causes for the lack of heat.
Thanks
Mike 1997 Blazer
MikePathfinder2001 is offline   Reply With Quote
Old 09-07-2006, 11:21 PM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: Fluid in Vacuum Resevoir
The transfer case to transmission seal fails on all 4x4 blazers and juimmys and s10s and when the seal goes it will overfill the transfer case which will then in turn have the vacuum line sucking up the fluid.
On flat ground go under your truck and with a drain pan under the transfer case remove the top fill plug for the transfer case.
If fluid comes out you know it is overfilled and the transfer case/ transmission seal is gone. Though this will take maybe years to overfill the transfer case, go just drop the excess and close it back up and check it in a couple of months.
Just make sure you dump the fluid out of the vacuum ball.
It is the transfer case or you are overfilling the transmission.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 09-08-2006, 10:36 PM   #3
MikePathfinder2001
Do I need to replace the transmission/transfer case seal?
Mike
Bookmarks
Google
Web AF
