Starter
vr555
09-07-2006, 12:16 PM
Hello,
I am looking for some advice on an issue I am having.
I have a 98 Rodeo and recently replaced the starter. The old starter was definitely bad and when I replaced it I was able to start the vehicle. After doing some errands, the vehicle will no longer start and it isn't doing anything....no clicking....etc. Would could possibly be the issue? loose connections...?
amigo-2k
09-07-2006, 12:22 PM
I yes I would start with loose connections and check the ground to the battery and the battery connections.
You could also have a bad new starter too.
Gizmo42
09-07-2006, 12:31 PM
Could also be an issue of the starter binding. I had that problem with mine and had to reinstall it several times before I got the right position. While you are checking the connections, take the starter loose (back off the bolts about half way) then try it and see if the starter turns.
I have gotten bad starters out of the box from all the major parts stores. Most checked good on the test bench at the store but a brand new 650 CCA battery wouldnt turn them over with it not even intsalled in the vehicle.
