04 TB leaking into cabbocatodee 09-06-2006, 04:39 AM has anyone had a problem with water leaking into the passenger and possibly the driver floor boards? i have taken it in twice to get it fixed while it was under warranty but the problem keeps coming back? does anyone know what might be causing this and if so how to fix it once and for all? some PLEASE help me........... rodeo02 09-09-2006, 11:05 AM First thing I would check is the rubber condensate drain hose in/under the engine compartment. It sticks out the pass side of the firewall and aims down. If that hose is plugged, water will build up from the a/c evaporator core and spill into the cabin. If that's good, I have heard of water leaks from the cowel area, around the WS wiper motor and wiring. A third common cause of leaks is around sun roofs if so equipped. Joel bocatodee 09-09-2006, 04:02 PM Thanks! I really appreciate the information. I will try to check it out this weekend. Thanks again! Automotive Network, Inc., Copyright ©2012
