02 Malibu Not the hazard flasherjgb_430 09-05-2006, 05:50 PM In a 2002 malibu i'm looking for the answer why teh turn signal fuse and hazrds fuse are blowing at the same time and i already replaced the very comon faulty flasher. I put new fuses in both slots and they last for less than a day any help would be appreciated THX Blue Bowtie 09-07-2006, 02:47 AM Welcome Aboard! There may be a problem at the turn/hazard switch, the wiring in the steering column, wiring at a lamp, or anywhere between. Unless you use the hazard lamps frequently, try replacing only the turn signal fuse and diagnose from there. Do all the lamps operate properly? Including the center brake lamp? Automotive Network, Inc., Copyright ©2012
