northstar performancesscapricewagon 09-04-2006, 01:56 PM hello to all ! does anyone have info on where or what fuel injectors can i use to replace my stock injectors, im changing the engine in my deville with a 300 hp northstar with port and polished heads as an extra,to make the extra power i need to get a set of ugraded injectors,fuel regulator,and fuel pump, and if i can find it a high flow water pump has anyone done such a upgade. i have to change engine anyway so i want to do upgrades now before engine goes in :grinyes: caddydaddy 09-04-2006, 10:00 PM Do you mean you are swapping the L37 engine into a base Deville that had a LD8 engine? If so, just be aware the the L37 relies on the steeper 3.71 transmission gears to get it into the powerband quicker. It's not the best choice for the stock base Deville transmission. It will bog at low RPMs. As for the injectors, check with RSM Racing. The FPR, fuel pump and water pump are more than adequate for higher power engines. Automotive Network, Inc., Copyright ©2012
