10a ignition fuse keeps blowingKingDiamond 09-03-2006, 07:24 PM I have a 10A ignition fuse located under the dash in my 1994 plymouth voyager. It repeatly keeps blowing on me. When I first went out on me yesturday I could replace it then drive for about 15 minutes then it would blow again. Now however when I replace it it blow almost immediatly when I put it in Drive and press the gas pedal. Notice I said "when I put it in Drive and press the gas pedal." because I can leave it in Park or Neutral slam the gas all I want and it wont blow. I can even put into Drive and it wont blow. But If I put it in Drive and press the gas hard or soft it will blow. Anyone have any Ideas? I could really use some help. Moppie 09-03-2006, 07:48 PM Well the ignition system experiances the most load when the engine does. So there is clearly a small short in there, that only shorts as the load goes up. Find the short and fix it :) 534BC 09-04-2006, 03:56 AM You are really saying that it'll idle in drive for a long time, even may putter around slowly, yet when pushing on the throttle it will blow fuse? I thionk you're saying that it has to have "drive " and "throttle to blow? Please check reverse and then powwer brake it without moving. Is there any lights that come on when in drive? KingDiamond 09-04-2006, 11:53 AM You are really saying that it'll idle in drive for a long time, even may putter around slowly, yet when pushing on the throttle it will blow Thats excatly what im saying. Although I noticed last night when I Idle for about 20 minutes in drive, it will blow. With engine cold I can go around the block a few times as long as I dont press the throttle, but once it gets hot it will it blow without throttle. I can go around the block forever in reverse with throttle. This is the 10A ignition feed fuse. KingDiamond 09-05-2006, 03:32 AM Ok now it will now blow when just put it in Drive throttle or no throttle. But still will go in reverse and park and i can give it full throttle. It has to be something that comes under load only in drive. Automotive Network, Inc., Copyright ©2012
