headlight problemsvipersys22 09-02-2006, 04:09 PM Hi, I own a 92' dodge Dynasty with a v6 and while driving at night with my headlights on, they turn on and off on there own, even if I switch to highbeams. Need help trying to find out problem? Thank you in advance yale329 09-15-2006, 12:44 AM Check all connections and clean with a can of electrical cleaner. Also check and clean every ground strap you can find under the hood. It could be in your headlight lever. Good luck. chism 09-29-2006, 06:07 PM I own a 1992 ford crown vic, i had the same trouble. lights would go on and off while driving. i changed my wiring hook up to my light switch as it was burnt (wiring hook-up) and as a result, would not touch when i hit bumps. you could see black burnt areas on the wiring hook-up area. Stevo2 09-30-2006, 07:14 AM Check out the headlight switch or replace it. Also check the connector that mounts on it as it may be burnt. Automotive Network, Inc., Copyright ©2012
