Re: Throttle body coolant bypass?
Keep in mind I have no experience with GM engines. But this is a topic I just ran across rather recently in a Mitsu forum. Some did it to clear up space, for convience in the engine bay, refering to teh same engines you did, as proof it will work fine. After doing this however, some had no problems, and some had issues with a much higher idling speed.
It's called the Fast Air Idle Valve, and basically it reads the coolant temp, and allows more air in, behind the butterfly in the TB, to bump up cold idle. So say normal idle is 700, some saw warm idles as high as 2,000. For others it worked fine. So my point is, make sure if you block this space off, make sure your blocking method is reversible...well that or I guess you could always just reset your base idle.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
-3sx aluminum pulley, FMIC, walboro pump, EVO 560ccs...sitting in garage
