Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-26-2002, 07:48 PM   #1
rrk127
rrk127
Corolla cranks but will not run
I have a 1990 Corolla (Geo Prizm actually, but Prizms have Corolla engine) with about 100K miles on it. Of late, the car has been giving me trouble starting. I have to crank it multiple times to start the car. That is: I crank, stop, wait 10 seconds, crank again and it runs. However, sometimes, I just cannot get it to run. I crank repeatedly and nothing happens. Whenver this happens, I have always been able to get it running with a push start. Also, it has never stopped while running. I have replaced the distributor cap, spark plugs and wires. The disgnostic code I get is 43 (NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM). I suspect that I am getting this code because I push started the car. I would like to keep this car for a while more - any suggestions on what might be the problem? I deperately need this car to keep me going!
rrk127 is offline   Reply With Quote
Old 10-18-2002, 01:24 AM   #2
dutchboy
dutchboy
fuel filter replacement...
and check fuel pump...and theres probably some relays whcih should be checked which control the fuel...
check spark...fuel ...and air and it should run....those are the main things to run a car...
dutchboy is offline   Reply With Quote
Old 10-18-2002, 01:47 PM   #3
nemo_wolf
nemo_wolf's Avatar
nemo_wolf
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
depending on how well you know your mechanic there is a tool/equipment they can use to check each part of your distributor to see exactly what is bad. you may want to ask about that cause it kinda sounds like a distro problem to me, but then again all i have is a rough description and ive had alot of distro problems lately.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Present
nemo_wolf is offline   Reply With Quote
Bookmarks
Google
Web AF
