97 Grand Prix GTP, Engine Miss Stupmed?jameslarsonsdsu 08-31-2006, 01:21 PM I have got a 1997 GTP with the SC 3.8. About two weeks ago, it developed a miss under load or acceleration. Yesterday, I changed the plugs and the #2 plugs electrode was burnt away. I thought I had fixed my miss but that didn't change it. Driving it for two weeks with a miss is what burnt that plug because the miss kept getting worse and now it is like it was two weeks ago. I have ohmed the injectors and 4 were 14ohms and 2 were 15ohms (good). I changed the fuel filter because I never had in the past six years and it was pretty sh!!ty. I could hardly blow through it. However, it didn't fix the problem but lets me know my fuel pump works well to push fuel through that bad filter. I am pretty good with cars but I an stumped at this point. Does anybody have any suggestions? Thanks BNaylor 08-31-2006, 01:28 PM How old are the ignition wires? And what brand spark plugs did you use? I'd try new wires first if they haven't been replaced. After that try swapping out the coil packs and see if the miss moves to another cylinder. Another possibility if the misfire is under load MAF sensor. Any mods? Welcome to AF. jameslarsonsdsu 08-31-2006, 01:45 PM They are the original wires. (no comments please) I will change the wires today. If that doesn't do it, is their a way to check coil packs. The only reason I knew which cylinder had a miss was because of the burnt plug. Thinking about it now, the wires have a pretty good chance of being bad. (10 years old and 180,000 miles, poor things). I'll get those changed today and post tonight. The plugs were Champion Platinum (.060) Thanks again corning_d3 08-31-2006, 02:21 PM You can check the coil packs, but even a bad one is likely to show good. This is especially true if it's heat related. I'm with Bnaylor, I'd swap coil packs and see if the miss moves.. BNaylor 08-31-2006, 02:42 PM 180K on the wires? I was lucky to see 80K on them before they start acting up. That supercharger gives off a lot of heat. You should can the Champion spark plugs. Get the AC Delco OEM Platinums or Iridiums. Autolite or NGKs would be another good choice. Let us know what you find. Good luck. GTP420 08-31-2006, 11:13 PM yeah my gtp had stock plugs and wires when I got it. At that point it had 120k... and still performing well. They make those suckers to last. corning_d3 09-01-2006, 12:12 AM I wonder why they ran the plug wires right over the S/C? I was working on one the other day and touched the s/c after a good run, OUCH! jameslarsonsdsu 09-01-2006, 12:27 AM I replaced the spark plug wires and everything is well. I guess I'm good for another 180,000 miles. :lol: Just kidding BNaylor 09-01-2006, 01:00 AM Thanks for the feedback. We'll put you into our record books for having the highest mileage on OEM plug wires in a GTP. Automotive Network, Inc., Copyright ©2012
