need helpmachete619 08-30-2006, 09:43 PM well when im driving and i turn right it makes like a knock nosie and when i back up and move the steerin wheel right it makes the knock nosie 2 wat could it be JSUsaxman 08-30-2006, 09:48 PM CV joints machete619 08-30-2006, 10:05 PM thnx bro imma go on a trip like dis saturday do i have ta get them fix before or can i jus drive like dat into i get them das2123 09-03-2006, 09:57 PM CV joints make a clicking or popping noise, not so much a knocking noise. Wollf 09-04-2006, 10:35 PM you can drive till they break then you drive no-where no-more if it breaks on the road a towtruck will be your taxi. yale329 09-11-2006, 01:02 PM If the Cv is okay, then it is your front wheel bearing. If you had new bearings pressed in as I did, they were dry or not pressed in properly. Usually a CV can be tested at any speed in a parking lot by making a very sharp right or left turn. Don't rule out your front bearings, I'ts odd if it does it in both turns. Wayne Automotive Network, Inc., Copyright ©2012
