Hot air our the vents
johnnydragon
08-26-2002, 03:56 AM
Is it a common problem in the 2000 to blow hot air our the vents? I saw a fix for it on www.nissan-offroad.net. Has anyone had the problem cured by opening up the holes in the cowl as suggested? Side note, is there a thread re: CalMini and their lift kits? Thanks. A new user, johnnydragon.
OffroadX
08-26-2002, 09:26 AM
This isn't the correct forum for questions, it's for answers to common questions (FAQ= Frequently Asked Questions) but assuming a moderator will move the thread...
Yes, it's a common problem. Yes, I and many others have done it and it works. It's a tedious job, but worth it.
Check the Suspension section for lift information. There is a search tool for the site as well, just drill down to the Xterra section before setting it loose or you'll search every make/model on the AF site.
Brent
philav
08-02-2004, 02:48 PM
Looks like the nissan-offroad.net info is off line, does anyone have current info on how to cure this problem? Thanks
OffroadX
08-03-2004, 10:41 AM
It's just a matter of punching/drilling out the holes in the cowl, or you can have the cowl swapped with a redesigned one per NTB02-031 (Nissan TSB).
Brent
