Mega Fuse Where?meintool 08-30-2006, 12:11 PM i have a fealing its the mega fuse because thats the only thing i havent checked because i dont know where it is or what it looks like i checked all the fuses in the passenger compartment and under the hood in the fuse box none are blown meintool 08-30-2006, 12:49 PM nevermind i found the mega fuse and removed it when i shake it sounds like loose metal..how do i go about testing this fuse out of the car Ohms? if so what readings should i get meintool 08-30-2006, 12:59 PM OMG i said screw it called ford to see if they had one and it was cheap so i busted this one open and come to find out it is deffinatly blown split right in the middle now i know why i bought a $120 alternator and a $70 battery all over a god damn 7$ FUSE zblu81 11-30-2006, 07:30 AM What year is your contour and where did you find this "mega fuse"? beyondloadedSE 11-30-2006, 08:02 AM What year is your contour and where did you find this "mega fuse"? I4 http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1311779&Forum=trouble&Words=megafuse&Match=Entire%20Phrase&Searchpage=0&Limit=3000&Old=allposts&Main=1311755&Search=true#Post1311779 V6 http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1097673&Forum=trouble&Words=megafuse%20V6&Match=And&Searchpage=0&Limit=3000&Old=allposts&Main=1095791&Search=true#Post1097673 zblu81 11-30-2006, 10:24 AM Thanks for the reply but after doing some reading I don't think this is what I need. I'm looking for a main fuse or relay. I installed a remote starter yesteday and it worked fine the first few times i tried it. Then I think I blew a fuse or relay by accidently grounding a hot wire from the remote start unit that i wasn't going to hook up. Now I ahve no power at the Ignition or Headlight switches. (no accesories, or vent/blower with the key on, no engine cranking,) Is there a relay that runs all of these or am I looking for more than one? beyondloadedSE 11-30-2006, 01:41 PM Thanks for the reply but after doing some reading I don't think this is what I need. I'm looking for a main fuse or relay. I installed a remote starter yesteday and it worked fine the first few times i tried it. Then I think I blew a fuse or relay by accidently grounding a hot wire from the remote start unit that i wasn't going to hook up. Now I ahve no power at the Ignition or Headlight switches. (no accesories, or vent/blower with the key on, no engine cranking,) Is there a relay that runs all of these or am I looking for more than one? do you have an owners manual that gives the locations of all the relays/fuses and what they protect? Id start there. zblu81 11-30-2006, 01:52 PM I wish i had that. I may just bite the bullet this time and have it towed. We've got bad weather moving in and I don't want to walk to work tomorrow. beyondloadedSE 11-30-2006, 02:14 PM Ok, I went out and pulled my manual out of my car. Heres the ones that I would take a look at. Chances are, if you have a blown fuse or relay, youve got an exposed wire somewhere. Im sure cutting in the harness for your remote start is probably related. Anyways, from the fusebox underneath the hood: Relay 1: Main Power Supply Fuse 4: Daytime Running Lights/Ignition (I would guess this one) Fuse 10: Ignition Switch From the fusebox underneath the drivers side footwell: Relay 16: Ignition zblu81 11-30-2006, 03:26 PM fuse10 was blown, I didn't check either of the relays. I will re-wire everything tonight and make sure it's right before replacing the fuse. Thanks a ton for all the help! zblu81 11-30-2006, 03:28 PM i'm also curious if you have a 1/4 mi. time slip for your contour. Automotive Network, Inc., Copyright ©2012
