Re: too much cooling?
he is asking weather or not you can "Over Cool" a car with the radiator being too large.
to answer your question:
radiator size is usually a reflection of the size, power, and load of the engine.
an 18 wheeler will have a bigger radiator than a pinto.
the size of a radiator will help cooling, but only to a point. there is a point at which putting in a bigger radiator just adds weight, and takes up space: Law of diminishing returns.
sure a bigger radiator will radiate more heat, but if your thermostat is working, your engine is running properly, and you are not racing in Le Mans, the stock radiator is usually sufficient. if you live in the Mojave, and enjoy racing at top speed across the desert, you may require a larger radiator.
if you modify your engine to produce say twice the power, you may need a bigger radiator.
otherwise, i'd stick with stock... unless you have a problem with overheating.
p.s. if you have a problem with overheating, i'd check things like your thermostat, or fan clutch if you have one. electric fans could short out and not pull air, or your radiator may be so old that the corrosion built up has clogged some of the cooling vanes in the engine block.
