Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Cars in General > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-29-2006, 03:52 PM   #1
kachok25
kachok25 Normal reputation
new 911 turbos WTF
OK does anybody know anything about the new 911s turbos? That crazy thing spools up and hits peak torque (460 ft/lbs!!) at below 2000 RPM, and does not run out of breath at 7000 RPM what do they do to ther turbos to give them such an ungodly power band?
kachok25 is offline   Reply With Quote
Old 08-29-2006, 09:54 PM   #2
Dyno247365
Dyno247365's Avatar
Dyno247365 Normal reputation
Re: new 911 turbos WTF
Are you talking about the rear mounted turbos?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Dyno247365 is offline   Reply With Quote
Old 08-29-2006, 11:11 PM   #3
2.2 Straight six
That thing got a Hemi?
2.2 Straight six's Avatar
2.2 Straight six 0
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
they're called variable geometry turbos. as the engine's revs climb they blades open out more. so effectively the turbo gets "bigger" as the revs climb.
so at a low rpm they're acting like small turbos that spool up fast, and at high rpm they open up more and act like much larger turbos.
they're nothing new, they're been around for years. but were usually the reserve of diesel engines.
Seatbelts Saved My Life
2.2 Straight six is offline   Reply With Quote
Old 08-30-2006, 10:37 AM   #4
kachok25
Cool is the Thermal effeciency as good as regular turbos?? Why don't all turbos spool up at 2000RPM or less?? How much can they change the AR or a turbo?
Old 08-30-2006, 10:30 PM   #5
KiwiBacon
KiwiBacon Normal reputation
The peak efficiency will be a little lower due to the drag of the stator vanes. But the efficiency band is much wider.
So they have no place on an industrial engine (think power generator running one RPM for ever) but on a road vehicle make a lot of sense.
One of the american cars had variable vane T25 turbos very early on. It seems they learnt lessons the hard way that moving parts and high EGT's of a petrol engine aren't friends.
But the Germans could well have found the answer.
As for why most turbos don't spool at sub 2000rpms?
On almost every diesel they do. On some petrol cars they do (twin turbo subarus boost almost that low). But at cruise it's terrible for fuel economy to create boost, then throttle it to a vacuum before the inlet manifold.
Supercars care more about power than MPG.
Here's a cross section showing the variable stator vanes.
KiwiBacon is offline   Reply With Quote
Old 08-31-2006, 12:44 PM   #6
kachok25
So run a bypass valve while crusing that engages the turbo when you punch it. That does not seem like an engineering problem.
Old 08-31-2006, 06:10 PM   #7
GreyGoose006
GreyGoose006 Normal reputation
good thinking... it would have to be computer conrolled and refrence the ECM and throttle position sensors to do that.
the major killer of great ideas like this is R&D funding. sure the technology is out there, but can someone convince their boss to let them spend $12Million on an engine that uses technology that is just now being perfected, and put it in a road car that gets driven anywhere between 3000 and 10,000 miles between oilchanges, and treated like shit on a daily basis, but still has to work long enough that the dealers dont have to repair them al under warranty... No.
you also have the problem of the fuel ratios going way lean, so you would need it to be adjustable automatically based on boost levels, and timing would change, so would the *IDEAL* cam profiles... it'd be a little more complex, but still feasable
How are the vanes actuated... what makes them open and close at RPMs?
is it air velocity, or solenoids or what?
GreyGoose006 is offline   Reply With Quote
Old 08-31-2006, 11:09 PM   #8
UncleBob
AF -Advisor
UncleBob Normal reputation
a bypass valve wouldn't "solve" the issue. The problem isn't so much with the turbo, its with the engine design. High performance cars have a combination of issues that don't make them very fuel efficient. The biggest one is usually the cam shafts.
Take a VW jetta/passat 1.8L Turbo. They spool very fast, because they have a very small turbo, but they get pretty decent mileage. They don't have the option of increasing the AR at higher RPM's, so the engine is really choked in the higher R's. Much different engine design.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
UncleBob is offline   Reply With Quote
Old 09-01-2006, 11:56 AM   #9
kachok25
If a proformance engine is not capable of getting good thermal efficency how do you explain the 1997-2002 Z28 over 3500lbs RWD and 300+hp getting 28mpg (if you don't drive it like it is ment to be driven ) that is the fuel effecency of a mild tune V6 FWD famaly sedan of that time. So I would not say that a proformance engines cannot get good effecency.
Old 09-01-2006, 01:54 PM   #10
2.2 Straight six
2.2 Straight six 0
overdrive. insanely high gearing allows the engine to operate at a very low rpm, yet the car's still moving at a good speed. so doing 60 on an interstate in 6th (their second overdrive gear) the engine's somewhere between 1,500-2,000rpm i believe.
Old 09-01-2006, 07:36 PM   #11
UncleBob
AF -Advisor
to keep this in perspective..... "300hp" (and I quote that loosely) out of a 5.7L engine is a tad bit different level of "performance" than the original car mentioned here
Old 09-01-2006, 07:42 PM   #12
Moppie
Time Travelling!
Moppie's Avatar
Moppie +150Moppie +150
Out of a 3.0L V6
But its still completely different to the power level out of the Porsche engine, which is almost twice as much, and makes more torque at 2,000rpm than the Nissan did at peak.
Whinning since 2001
Moppie is offline   Reply With Quote
Old 09-02-2006, 04:51 AM   #13
KiwiBacon
You've still got a lot of frictional loss there. Still spinning the turbo, still pumping air. Just letting the recirculated air go around in circles getting hotter and hotter.
Seamless transition would also be a major issue.
Old 09-05-2006, 02:36 PM   #14
kachok25
Aw forget about seamless transitions, I love a turbo that slams me back in my seat
Oh an considering the proformance on the 97-02 Camaro I would not doubt that 300hp quote at all. And now there is the LS2s with 400hp still getting above avrage MPGs.
Old 09-05-2006, 09:27 PM   #15
UncleBob
AF -Advisor
that one I know about, unlike the camaro reference.
There was a day when the HP ratings were pestimistic due to regulations. If you had a car that was rated for 300HP, often they would have 325HP to the rear wheels.
Those days are over though. The 400hp rating for the LS2 is probably at the flywheel, it definitely isn't at the rear wheels. The stock LS2's I've seen dyno'd were around 350 RWHP.
Bookmarks
Google
Web AF
