Final: Parting out Highly Modded 2.0L
nolanspawn
08-27-2006, 03:22 PM
For those on this forum that dont know me, you can read my reputation on Probetalk http://forums.probetalk.com/itrader.php?u=15981
Willing to entertain reasonable offers
(ENGINE)
*16V DOHC 2.0L I4 Crate Motor (Not a Rebuild) (8,000 miles)(Comes with Crower Cams) :
$800 pickup prefered
This motor will come without the oil pan, however if you want the AWR oil pan as well I will cut you a deal on the whole package.
*AWR Baffled Deep Sump Oil Pan:
$250 + shipping (SPOKEN FOR BY bcmurphy87)
http://www.nolanspawn.com/pics/awroilpan01.jpg
http://www.nolanspawn.com/pics/awroilpan02.jpg
http://www.nolanspawn.com/pics/awroilpan03.jpg
*TWMotorsports Resonated Testpipe:
$65 + Shipping
*MSD 6AL :
$125 shipped
MSD has ALOT of scratches and wear on the case. The paint is very faded. Looks a little rough, however still performs as it should.
*MSD Blaster High-Vibration Coil:
$35 shipped
*B&M Oil Cooler, B&M Oil Filter Relocation Kit, B&M Thermostatic Control Valve:
$130 + shipping (SPOKEN FOR BY bcmurphy87)
This comes with Aeroquip AQP Socketless Hose, all barb fittings and hose clamps, mounts the cooler to the front ofradiator on the right drivers side. Might fit the 2.5L like this, would recommend use on the 2.0
*Taylor Racing Battery Relocation Kit:
$75 + Shipping
Comes with positive and negative cables for a full run from the front of the car to the back. Also comes with some brackets for mounting I made.
*AWR Racing All Aluminum High Performance Radiator:
$300 + shipping (SPOKEN FOR BY bcmurphy87)
http://www.nolanspawn.com/pics/awrradiator2.jpg
(TRANSMISSION)
*Spec Stage III :
$250 + shipping
Has about 4K miles on it
*Pair of 2.0 MTX axels
$100 + shipping
One has a rip in the boot and I am thinking about warrantying it through AutoZone since that is where I purchased it.
(BRAKES)
*Front 94 GT Calipers and Rotors:
100 + shipping
Unsure of the mileage on these, they do not come with lines.
(SUSPENSION)
*Procarparts Rear Strut Bar :
20 + shipping
(STOCK PARTS)
*1993 2.0 Denso 02 Sensor :
$30 shipped
Has about 15K on it.
*1993 2.0 Distributor :
$65 shipped
Comes with brand new cap and rotor.
*Stock 2.0 MAF :
$30 shipped
*Brand New Starter from Oreilly Auto :
$85 Shipped
Has less than 2K Miles on it
*Brand new Alternator from Oreilly Auto:
$70 + Shipping
Has less than 2K miles on it
*2.0L Passenger side motor mount and drivers side top transmission mounts :
$55 shipped
Both of these mounts were filled with polyurethane from Home Depot.
*Protege 2.0 power steering pump and lines :
$100 + shipping
Reason for doing this swap would be to change the route of the powersteering lines so that they dont drape over the 2.0 motor. Good for someone looking to clean up the bay a little bit.
(OTHER)
*17x7.5" Excel DL-46's w/ Kuhmo Ecsta 711's (50% tread) :
$400 + shipping
1 is curbed in a spot of it pretty deap. Tire never has had loosing air problems, always kept pressure. They have some rust spots on them but i think they just need to be throughly cleaned by hand to remove it. Its from when I was deployed and where water sat Im guessing. Tires have about 50% tread on them.
http://www.nolanspawn.com/rims1.jpg
http://www.nolanspawn.com/rims2.jpg
