Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mazda > MX-5/ Miata
Old 08-23-2006, 01:50 PM   #1
pdupuis
pdupuis Normal reputation
90 miata performance in the ditch
I bought a 90 Miata about 6 months ago with 172,000 miles. Now I have about 187,000. In the past month the performance has gone down noticably. Climbing a hill requires being in 4th or 3rd and my speed dropping to 40 or less. My milage has dropped from 35 mpg to about 29. When just started, it pops when I come off the gas. Any ideas?
pdupuis is offline   Reply With Quote
Old 09-27-2006, 01:15 PM   #2
BrokenSol
BrokenSol Normal reputation
Talking Re: 90 miata performance in the ditch
sounds like normal wear for a miata. when was the last oil change? changed the plugs/wires recently? the pop is pretty common, miata ecu's tend to run rich. try replacing that cat w/ a test pipe
BrokenSol is offline   Reply With Quote
Old 10-14-2006, 12:50 AM   #3
aj817
aj817's Avatar
aj817 Normal reputation
Send a message via AIM to aj817
That kind of stuff started happening to me recently. I'm doing an engine swap now. The rear seal was leaking oil onto my clutch. Ruined my clutch and flywheel. Someone first told me that it was the slave cylinder, but the problem wasn't fixed when I replaced it. I had to look further into it, and the problem was a lot worse than I thought it would be. Be careful. (The slave cylinders to wear out fast on those cars.)
It does sound about normal though. Oil and plugs and wires are good to check.
I have a test pipe instead of a cat. It doesn't really do much for the gas mileage...
aj817 is offline   Reply With Quote
Old 12-29-2006, 02:39 AM   #4
sken7
sken7 Normal reputation
Did you check the releaf valve connecting valve cover to intake manifold.
sken7 is offline   Reply With Quote
Bookmarks
Google
Web AF
