Re: NewB clutch question
I just had the same problem with my '94 Miata. Has the engine got hotter, the shifting became more difficult. It turns out that my clutch slave cylinder had a small leak, and as the fluid got warm, the leak became worse making stepping on the clutch less effective. I would suspect that you have a small leak in your master or slave clutch cylinder.
Anthony
