Originally Posted by ryanvv355
I have a dragging pad on the inboard front driver side. the rotor, pads and caliper are new. It goes away when i turn left. any thoughts.
Caliper still isn't sliding smoothly for some reason...bent hardware, damaged slide surface, making hard contact with something it shouldn't be....
With the piston retracted fully (I mean pushed ALL the way back, like with a c-clamp or pad spreader), and the caliper mounted up, you should be able to slide that caliper back and forth across it's full range of movement easily with two fingers and a thumb...if not, there's your problem, figure out why...
I have a couple of questions. How did you determine it's the inboard? And when you say it goes away, I assume you mean it's making scraping or dragging noises until you turn? Is the hub bearing OK (no lateral drift?)
