light
Google
Web AF
Jmoney3318
08-22-2006, 01:31 AM
ok question if i wanna hook up neons or somthing to make them turn on when the lights come on how do i do this from the drivers side i dunno wut wire to cut into or what any help or pictures would help
Gir-_-
08-22-2006, 07:22 AM
could check the volts on the 194 bulbs on each side :dunno:
for my one LED in my trans temp gauge... I have it hooked up to the grey wire from the dimmer ... *Dims/comes on when dash lights come on*
But for under the driver/passenger u could find a
xeroinfinity
08-22-2006, 10:42 AM
if you are putting the neons under the car you Dont want them to come on when you turn your lights on.
Plus they usually hav a relay that needs wires up to energixe the neons.
Jmoney3318
08-22-2006, 10:50 AM
im not just talkin about neons i need like th backlight of my cluster gauge to light up and i want em to come on when the lights turn on as Gir said he used the grey dimmer wire what would be the best way to tap into a wire cut the stuff around the wire and just bend it around it or is there something i can buy ?
Gir-_-
08-22-2006, 02:04 PM
k if ur talkin about the back light of the cluster gauge... you'd be better off on placing and LED 194 in the place where the bulb is located...
What color is ur gauge cluster at night? ... hopefully either red or blue :dunno:
www.pfyc.com ... under grand am -> Interior -> very bottom of the page u can find the autometer LEDs that might be specific for your color... expensive yea but they're molded different than a normal LED and shine light around rather than in 1 direction .. I placed my extra blue one down where my shift light was because the blue on my shift gauge was like a teal color ... blue autometer gauge fixed it right up and is brighter than the 194 OE Bulb... lights up very very blue and covers alot of area with light...
Jmoney3318
08-22-2006, 03:23 PM
well heres my situation the thing that holds the 194 bulbs have supposedly broke cuz they dont like up and ive tried everything so my theory is gettin some of that white Neon wire stuff and outline the gauges so it can light up cuz i have the blue intelliglow needles but its not enough light to see my rpms and speed and all that nonsense so i wanna hook up that neon wire so it come son when the headlights come on.
xeroinfinity
08-22-2006, 07:38 PM
Hey Jmoney3318, pretty sure you can do it but those neon rope things probly need to be on just a power wire and not the dimmer.
Most neon lights that go inside need a steady power.
You can test those lights on the floor with a volt meter.
It could be jsut the fixtures bad or broken.
Thiers 1 screw that holds them on, comes off easy.
Maybe you can see whats up and or wire your neons to those power wires, but if the dimmers turned to far down the lights may not work :dunno:
Might just need a switch and work them manually.
xeroinfinity
08-22-2006, 07:39 PM
Jmoney3318, you still not getting your dash lights to work ?
Jmoney3318
08-22-2006, 08:31 PM
na man i cant get em to work i think the thing they sit in is fried or something i dunno i tried everything, but yea i guess my best bet would to just be to hook them up to a switch and do it all manually
Google
Web AF
